static snat assignment not working as expected
I'm trying to do a static SNAT assignment for a virtual server based on the client's source IP address. I'm using the following iRule to do this:
when RULE_INIT {
Use a local array to configure SNAT addresses.
These addresses must be defined in a SNAT pool.
Follow the pattern of the existing addresses to add more than three.
set static::snat_ips(0) 10.x.y.253
set static::snat_ips(1) 10.x.y.254
when CLIENT_ACCEPTED {
Restrict port access to HTTP or HTTPS
If it's a valid port, assign a SNAT entry and allow the connection to continue.
if it's not a valid port, reject the connection.
if { ( [TCP::local_port] == 80 ) or
( [TCP::local_port] == 443 ) or
Calculate the crc32 checksum of the client IP.
Use the modulo of the checksum and the number of SNAT IPs in the array.
to select a SNAT IP address.
snat $static::snat_ips([expr {[crc32 [IP::client_addr]] % [array size static::snat_ips]}])
else {
reject
At this point in time, I'm the only client using the virtual server with this iRule, and in fact I have a tcpdump running that verifies that no one else is using this virtual server. But when I look at my snat translations in TMSH, I see that both of the SNAT IPs are being assigned.
sho ltm snat-translation 10.x.y.253
Ltm::SNAT Translation: 10.x.y.253
Traffic ServerSide
Bits In 907.7K
Bits Out 3.0M
Packets In 439
Packets Out 410
Current Connections 3
Maximum Connections 3
Total Connections 3
sho ltm snat-translation 10.x.y.254
Ltm::SNAT Translation: 10.x.y.254
Traffic ServerSide
Bits In 688.0K
Bits Out 1.1M
Packets In 217
Packets Out 168
Current Connections 0
Total Connections 10
Does anyone have any idea why this would be happening? I would expect my source IP address to always be assigned the same SNAT entry. I cleared the SNAT counters while my TCPDump was running and I verified that the only client IP address that accessed this virtual server after that point in time was my IP address.
Any help would be greatly appreciated.
Thanks, Robert
- Vijay_E
Cirrus
Are the SNAT IPs being used by any other configuration object or may be the iRule is assigned to some other VS ? Can't you utilize 1 pool member in the default pool attached to the VS and then do a tcpdump on the server ? That should be more definitive, assuming you are inserting the client IP in XFF header.
or add a log statement in the iRule just below the snat IP selection:
log local0. "CLIENT IP - [IP::client_addr] - Selected SNAT - $static::snat_ips([expr {[crc32 [IP::client_addr]] % [array size static::snat_ips]}])"
