Sanal_Babu
Cirrus
Nov 29, 2017SSL Settings on LTM
Gents,
Do we need to configure the SSL profile (client& Server) in LTM when the certificate is on back end server. Or leave it blank?
- Samir_Jha_52506
Noctilucent
where do you want to terminate ssl connection LTM or Server? if server then no need to attach client SSL profile on VIP & just apply serverssl profile on VIP . Try it will work.
- KT_271103
It is based on requirement. If you wants to protect client to F5 like Banking sector then use certificate in F5 else use certificate in server.
