Tetzi_56467's avatar
Tetzi_56467
Aug 04, 2008
SSL persistance with http(s) proxies
Hello community,
I have the following problem, maybe someone can help me solving it.
Scenario:
I have an inner http proxy server for http and https requests.
This ( the other one is hot standby) proxy forwards the requests to the outer (DMZ) proxies.
The IP Adress the inner uses is a VIP/VS on the F5 LTM, loadbalancing the requests aso.
my problem is the SSL persistance.
Simple http requests are pers. through an iRule matching "X-forwarded-for" which the inner proxy adds
to the (http) requests.
For https request this is not added, and all pre-defined pers.profiles doesn´t work.
The http_request in an iRule doesn´t work , I think because of the CONNECT Statement in the initial request
and the following ip packets have an http header, but only containing "proxy-connect-hostname" and "proxy-conenct-port".( have done a lot of captures with and without proxy)
When I look into the definition of http_request, the above http header is not a valid request in the point of view from F5.
Does anybody have an idea ?
I have tried to match on "proxy-connect-hostname" but maybe my iRule wasn´t correct.
Thanks and regards,
Markus
