Vadiraj_95604
Jun 17, 2011SSL offload using TMSH
Hi ,
Below is the config i have scripted , not sure this is correct , please help me i am new to tmsh
create ltm virtual internal-443 Pool internal-443 destination 10.1.10.186:443 mask 255.255.255.255 snat automap ip-protocol tcp persist replace-all-with { ssl } profiles { { http } internal { context clientside } }
Thanks in advance
- hoolio
Does it work? Can you post the resulting virtual server using 'list /ltm virtual internal-443'?
Aaron - mockj2_63228
For anyone who looks to this thread for an answer:
To set up SSL offload via TMSH, you set the SSL profiles (both client and server side) using the 'profiles' option.
i.e.
create ltm virtual VSName destination 10.10.10.10:443 pool PoolName profiles add {clientsslprofile {context clientside} serversslprofile {context serverside}}
