SSL Forward Proxy Issue
Hello?
I have a Question.
The Customer used F5 SSL Forward Proxy.
Model : F5 BIG-IP 4000s Module : APM + SSL ForwardProxy + URL Filter OS : 11.6.1 + ENG Hotfix
the Bluecoat SSL Forward Proxy can SSL decryption Site but F5 SSL Forward Proxy can't SSL Decryption Site
I Check the Pcap File and I Found RST , Ack Packet. But I don't Know, why Sending Reset Packet.
SSLDUMP [root@sslfwd:Eval:Active:Standalone] config ssldump -r /var/tmp/161129_SSLFail_Test-02.pcap New TCP connection 1: 192.168.10.183(50581) <-> 210.220.13.61(443) 1 1 0.0027 (0.0027) C>S Handshake ClientHello Version 3.3 cipher suites TLS_RSA_WITH_AES_128_CBC_SHA256 TLS_RSA_WITH_AES_128_CBC_SHA TLS_RSA_WITH_AES_256_CBC_SHA256 TLS_RSA_WITH_AES_256_CBC_SHA TLS_RSA_WITH_RC4_128_SHA TLS_RSA_WITH_3DES_EDE_CBC_SHA Unknown value 0xc027 Unknown value 0xc013 Unknown value 0xc014 Unknown value 0xc02b Unknown value 0xc023 Unknown value 0xc02c Unknown value 0xc024 Unknown value 0xc009 Unknown value 0xc00a TLS_DHE_DSS_WITH_AES_128_CBC_SHA256 TLS_DHE_DSS_WITH_AES_128_CBC_SHA TLS_DHE_DSS_WITH_AES_256_CBC_SHA256 TLS_DHE_DSS_WITH_AES_256_CBC_SHA TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA TLS_RSA_WITH_RC4_128_MD5 compression methods NULL 1 2 0.0368 (0.0340) S>C Handshake ServerHello Version 3.3 session_id[32]= 65 b6 34 e9 9c b3 af 98 59 ea b0 2b 44 f7 c2 b2 1d 03 50 01 92 97 2b be a3 53 00 95 d8 a1 1c bf cipherSuite TLS_RSA_WITH_AES_256_CBC_SHA256 compressionMethod NULL 1 3 0.0368 (0.0000) S>C Handshake Certificate 1 4 0.0368 (0.0000) S>C Handshake ServerHelloDone 1 5 0.0380 (0.0011) C>S Handshake ClientKeyExchange 1 6 0.0380 (0.0000) C>S ChangeCipherSpec 1 7 0.0380 (0.0000) C>S Handshake 1 8 0.0393 (0.0013) S>C ChangeCipherSpec 1 9 0.0394 (0.0001) S>C Handshake 1 10 0.0772 (0.0378) C>S application_data 1 0.1363 (0.0590) S>C TCP RST
SSL log debug, iRule log Debug but i can't found Faillog ( tail -f /var/log/ltm )
how can i do?
- Kevin_Stewart
Employee
Let's first take a closer look at the captured SSL handshake:
ssldump -r /var/tmp/161129_SSLFail_Test-02.pcap New TCP connection 1: 192.168.10.183(50581) <-> 210.220.13.61(443) 1 1 0.0027 (0.0027) C>S Handshake ClientHello Version 3.3 cipher suites TLS_RSA_WITH_AES_128_CBC_SHA256 TLS_RSA_WITH_AES_128_CBC_SHA TLS_RSA_WITH_AES_256_CBC_SHA256 TLS_RSA_WITH_AES_256_CBC_SHA TLS_RSA_WITH_RC4_128_SHA TLS_RSA_WITH_3DES_EDE_CBC_SHA Unknown value 0xc027 Unknown value 0xc013 Unknown value 0xc014 Unknown value 0xc02b Unknown value 0xc023 Unknown value 0xc02c Unknown value 0xc024 Unknown value 0xc009 Unknown value 0xc00a TLS_DHE_DSS_WITH_AES_128_CBC_SHA256 TLS_DHE_DSS_WITH_AES_128_CBC_SHA TLS_DHE_DSS_WITH_AES_256_CBC_SHA256 TLS_DHE_DSS_WITH_AES_256_CBC_SHA TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA TLS_RSA_WITH_RC4_128_MD5 compression methods NULL 1 2 0.0368 (0.0340) S>C Handshake ServerHello Version 3.3 session_id[32]= 65 b6 34 e9 9c b3 af 98 59 ea b0 2b 44 f7 c2 b2 1d 03 50 01 92 97 2b be a3 53 00 95 d8 a1 1c bf cipherSuite TLS_RSA_WITH_AES_256_CBC_SHA256 compressionMethod NULL 1 3 0.0368 (0.0000) S>C Handshake Certificate 1 4 0.0368 (0.0000) S>C Handshake ServerHelloDone 1 5 0.0380 (0.0011) C>S Handshake ClientKeyExchange 1 6 0.0380 (0.0000) C>S ChangeCipherSpec 1 7 0.0380 (0.0000) C>S Handshake 1 8 0.0393 (0.0013) S>C ChangeCipherSpec 1 9 0.0394 (0.0001) S>C Handshake 1 10 0.0772 (0.0378) C>S application_data 1 0.1363 (0.0590) S>C TCP RSTA quick observation of this handshake reveals a few things:
This is the model of a perfect (RSA-based) SSL handshake. You can even see at the end the application_data exchange, which is the symmetrically encrypted message traffic that happens after a successful TLS handshake.
Looking at the SSL properties of this site at SSLLabs, aside from getting an F grade for its SSL implementation, it reportedly doesn't support TLS 1.1 and TLS 1.2, but clearly from this capture, you see that the client and server are successfully using TLS 1.2 (version 3.3). So I'm curious, which side of the BIG-IP did you take this capture? If SSLLabs is correct, the server side would not have been able to negotiate beyond TLS 1.0.
- Kevin_Stewart
Employee
Using "ALL" in the cipher string just provides access to all of the possible ciphers that the F5 supports, and is generally not a best practice.
What I'm asking is that you provide a capture of the server side SSL handshake (F5 to server). This is where the reset is probably coming from.
