Squeak_117117's avatar
Squeak_117117
Oct 30, 2017
Solved
SSL connection build-up issue
Hello all! I´ve a wierd ssl connection build-up issue. It looks like a normal SSL Client hello/server hello but in line 24 the connection seems to be interrupted somehow. I´ve got this error from the ltm log Connection error: ssl_codec_: received alert (48)
This is the output from a tcpdump .
213.199.125.28 are the bigip device. 10.67.219.41 is the client.
Thanks in advance.
