Michael_107360's avatar
Dec 10, 2013
SSL Caller Authentication and Access Control
We have a web service that wishes to use client certificates for caller authentication and access control. The client certificate is sent as part of the SSL handshake (when the server is configured to request it). I am wondering if it is possible to do the following at the F5, or if APM is needed: 1) Terminate the SSL connection at the F5 2) Require a client certificate be provided on that connection 3) Check that certificate against an Company-provided trust store (which will contain a certificate, issued by us, for each caller of the web service) 4) Extract the subject from the client certificate and add it to an HTTP header passed to the (downstream) apache server
  • Yes it is possible. Apply a clientssl profile with Client Certificate set to "require", and Trusted Cert Authority set to your CA, the apply this iRule;-
    when CLIENTSSL_HANDSHAKE {
         Check if the client supplied one or more client certs
        if {[SSL::cert count] > 0}{
         Check the first client cert subject
        set subject [X509::subject [SSL::cert 0]]
         Remove the customer header if already present
        HTTP::header remove "X-subject"
        HTTP::header insert "X-subject" $subject
