roshan_01_13770's avatar
roshan_01_13770
Nov 28, 2013
sshd[20032]: fatal: Read from socket failed: Connection reset by peer
Hello F5 Experts
I have two F5 BigIP - LTM 11- load balancers, When the Monitoring try to logon to these it gives the below Error message.
I have restarted the sshd service on both, but no luck.
Is this something related to rsa keys ?
Can you please help ?
  • Can you clarify where that message comes from - the f5 device itself or another device that is used to access the device. Might be worth doing this from a device on which you have a browser open to the f5 GUI to ensure that this is not a connectivity issue, or perform a ping to the device first. SSH does have a configuration option to set which hosts can login via ssh - System>Platform>SSH IP Allow. It is worth checking this as a first step.
  • Emad's avatar
    Emad
    Validate you SSH Settings for SSH IP Allow in Platform Settings. Add monitoring server IP there. System > Platform
  • Dear Pete - Thanks for your reply. It is the Monitoring servers who gets this error message. I will so your suggested tests and come back to you.
    Dear emi Will try that too and come back to you as well.
    Thanks for your help.
