Source port based load balancing using the persistence least connection
We have 1400 client with define source port from 8000 to 10000 and destination is 2 server for example (x.x.x.x and y.y.y.y)
We need irules for 8000 to 8500 source port load balance to x.x.x.x server if x.x.x.x fail send to y.y.y.y same thing goes all port.
Please help us to create the irules.
1) Source port 8000 to 8500
2) Source port 8501 to 9000
3) Source port 9001 to 9500
4) Source port 9501 to 10000
when CLIENT_ACCEPTED {
if { [TCP::client_port] starts_with "8000" ends_with "8500" } {
pool pool1
} elseif { [TCP::client_port] starts_with "8501" ends_with "9000" } {
pool pool1
elseif { [TCP::client_port] starts_with "9001" ends_with "9500" } {
pool pool1
elseif { [TCP::client_port] starts_with "9501" ends_with "10000" } {
pool pool1
Hi Faizan,
You can use less or grater oparators.
when CLIENT_ACCEPTED { if { [TCP::client_port] >= 8000 && [TCP::client_port] <= 8500 } { pool pool1 } elseif ...- Faizan
Hi Eaa,
Thanks for helping me.
