Andrea_Folco_11's avatar
Andrea_Folco_11
Mar 06, 2014
Some solutions for the proxypass iRules in section ProxyPassSSLProfiles
Hi, in the proxypass v10/v11 i have modify something in the proxypassSSLProfile section. I think is good create more then one datagroup with the sslprofile. I modified this section and corrected some issue. Now the users can create more then one ProxyPassSSLProfiles with sintax similar of the original proxypass. I have correct the string with findclass and use the new class functions.
The following code will look up SSL profile rules from
the Data Group "ProxyPass[virtual server name]SSLProfiles" and apply them.
The format of the entries in this list is as follows:
All entries are separated by spaces, and both items
are required.  The virtual server also will need to
have any serverssl profile applied to it for this to work.
   when SERVER_CONNECTED {
if {$bypass} {
    return
    set class_exists_cmd "class exists ${clname}SSLProfiles"
if {! [eval $class_exists_cmd]} {
    return
set pool [LB::server pool]
    regsub "^.*/" $pool "" pool
    regsub remove /Common/ in the  [LB::server pool]
    set profilename [class lookup $pool ${clname}SSLProfiles]
if {$profilename eq ""} {
    if { [PROFILE::exists serverssl] == 1} {
         Hide this command from the iRule parser (in case no serverssl profile is applied)
        set disable "SSL::disable serverside"
        catch {eval $disable}
    return
if { $static::ProxyPassDebug > 0 } {
    log local0. "$log_prefix: ServerSSL profile $profilename assigned for pool $pool"
     Hide these commands from the iRule parser (in case no serverssl profile is applied)
    set profile "SSL::profile $profilename"
    catch {eval $profile}
    set enable "SSL::enable $profilename"
    catch {eval $enable}
    log local0. "$log_prefix: ServerSSL profile must be defined on virtual server to enable server-side encryption!"
