Asakura_6529
Oct 18, 2007SOL7530 Problem: snmpd.conf is synchronized
Snmpd.conf is synchronized at ConfigSync. Are there another workaround?
- JRahm
Admin
Comment out the referenced line in your cs.dat file in both systems, or simply change the reference from file to ignore
Comment it out
/usr/libdata/configsync/cs.dat:
save.2340.file = /config/snmp/snmpd.conf
Change the attributes
Keep original setting in a comment for reference
save.2340.ignore = /config/snmp/snmpd.conf - Asakura_6529
Thanks, but I want to save the snmpd.conf in ucs, and I worry about the cs.dat is overwrited in future upgrade.
Are there another workaround for SOL7530?
SOL7530: Configuring an SNMPv1 trap to use a source IP address other than the management IP address.
