luoye's avatar
luoye
Aug 27, 2017
SOAP Monitor Failed
Hi all:
I builded a soap monitor,but it failed. Big-ip 11.5.4.Here is the debug log:
endpoint = http://170.100.130.107:9080/ImageAdminPortal/services/ProcessMessage
namespace = http://www.topcheer.com/ method name = processRequest param name = xml param type = string param value = return type = string return value = fault = 0 debug = 1 SOAP action = (null) SOAPHTTPProtocol::Close() SOAPProtocolBase::Close() CLOSED Adding string parameter xml = (string)
who can give me some advices??thanks
  • luoye's avatar
    luoye
    There is the monitor pcaket:
    POST /ImageAdminPortal/services/ProcessMessage HTTP/1.1 Host: 170.100.130.107:9080 Connection: Keep-Alive User-Agent: EasySoap++/0.6 Content-Type: text/xml; charset="UTF-8" SOAPAction: Content-Length: 998
    http://schemas.xmlsoap.org/soap/envelope/"; xmlns:A="; xmlns:s="; xmlns:y="; xmlns:iControl="urn:iControl" E:encodingStyle="; ' target="_blank" rel="nofollow">http://www.topcheer.com/">; HTTP/1.1 200 OK Content-Type: text/xml; charset=utf-8 Content-Language: zh-CN Transfer-Encoding: chunked Date: Tue, 22 Aug 2017 06:14:18 GMT Server: WebSphere Application Server/6.1
    7c9 http://schemas.xmlsoap.org/soap/envelope/"; xmlns:xsd="; xmlns:xsi="; xmlns:ns1="
