Ben_Jacobs_8776
Jun 29, 2007SOAP Health Monitor
Sorry if this has been posted before. I'm relatively new to Big-IP and haven’t done anything yet with iRules.
We’re trying to get a pool which monitors a SOAP listener working, but the default SOAP health monitor is not working for us. There is no way to provide a value for a ‘SOAPAction’ and without it we always return a 404 error. I’ve been told that there is a way to get this working with an iRule.
I really have no idea where to start on this, but if someone has already done an iRule to do this any help would be appreciated.
Thanks.
- spark_86682Historic F5 AccountThere is a workaround for this issue where you use a virtual with an iRule attached as your monitor target. So your config would look like:
monitor soap_mon { defaults from soap dest 10.10.10.99:http method "HealthCheck" namespace "http://example.org/" param type "string" protocol "http" return type "string" return value "LOOKS GOOD" urlpath "/soapmon.cgi" } pool my_pool { monitor all soap_mon member 10.10.10.100:http } pool soap_health_check_pool { member 10.10.10.100:http } virtual soap_health_check { destination 10.10.10.99:http snat automap ip protocol tcp profile http tcp pool soap_health_check_pool rule soap_health_rewrite }
And use an iRule like:rule soap_health_rewrite { when HTTP_REQUEST { HTTP::header replace SOAPAction "Some_SOAP_Action" } }
That's a rough draft that should get you started... - Ben_Jacobs_8776
Thanks.
It looks like setting up the health monitor this way will only check to see if the Virtual Server is up; it won't be able to see if the listner on an individual node is down. So if one node is down, the whole cluster will be down. - Deb_Allen_18Historic F5 AccountI am not intimately familiar with all the potential forms a SOAP request could take, but if a request sufficient for validating the health of the server could take the form of a GET for a specific URI with the correct Host header and SOAPAction header, perhaps a simpler option would be to create an HTTP monitor based on the built-in HTTP monitor template, specifying the appropriate headers, following this example on AskF5:
"Writing full HTTP commands for Extended Content Verification (ECV) or Extended Application Verification (EAV) health monitors" (Click here)
HTH
/deb
