JoshP_187840's avatar
JoshP_187840
Feb 18, 2015
SNMP with collectd and graphite
I'm trying to move the performance graphs available in the configuration utility outside of the device into our graphite environment. Following the documentation here (https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/tmos-concepts-11-1-0/tmos_snmp.html); here is the relevant part of my snmp.conf for collectd:
    Type "if_octets"
    Table true
    Values ".1.3.6.1.4.1.3375.2.1.1.2.1.3" ".1.3.6.1.4.1.3375.2.1.1.2.1.5"
    Type "if_octets"
    Table true
    Values ".1.3.6.1.4.1.3375.2.1.1.2.1.10" ".1.3.6.1.4.1.3375.2.1.1.2.1.12"
Then in graphite, I'm trying to do this:
diffSeries(lb01.snmp.if_octets.0.tx, timeShift(lb01.snmp.if_octets.0.tx,"-10s"))`
...I'm not yet worried about multiplying by 8 or dividing by 10 because the graphs just simply don't match, regardless of scale. Any idea what I might be doing wrong here?
  • Just in case anyone comes across this, the answer was much easier than I thought... graphite has a "perSecond" function which handles interpreting the data appropriately.
  • Has anyone a WORKING configuration example to get VS traffic data from F5 using collectd? I'm using cacti but I want to put fine grained data into my db. Thanks
