Matthew_Hutchin's avatar
Matthew_Hutchin
Apr 09, 2008
SNMP VS and Pool monitoring
I am trying to get my VSs and Pools monitored with SNMP on the LTM the I would like a trap sent to an external monitoring syste like ArcSite. Has anyone tried with yet? Can anyone point me in the right direction?
Matt
  • cb,
    Thanks for helping me out but I am still having a little trouble. I have created the user_alert.conf added the logger -p for syslog-ng but the alertd doesn't start back up. Anything I can do to troubleshoot this?
    Matt
  • hoolio's avatar
    hoolio
    If you try to start alertd using bigstart start alertd, you should see a syntax error with a line number noted in the standard output. Else, I think you can check /var/log/messages for the error. Chances are, you're missing a semi-colon at the end of one of the configuration items. If you get stuck, try posting the block that the error is in.
    Aaron
  • Hi Aaron,
    Thanks for the input. Here are the steps I used to try and setup a custom snmp trap.
    I add this to the user_alert.conf file
    alert BIGIP_MCPD_MCPDERR_NODE_ADDRESS_MON_DOWN "Node (.*?) monitor status down." { snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.12"
    Then I run
    logger -p local0.warning "Pool member 10.10.64.14:80 monitor status down."
    Once I run that command I keep getting:
    logger: Re-starting alretd
    The restart message just keeps repeating itself over and over again
  • hoolio's avatar
    hoolio
    Sorry, the log file errors would be logged to is /var/log/ltm. Do you see any related errors in /var/log/ltm?
    I added an invalid line to the alert.conf and see the following entry in /var/log/ltm:
    Apr 14 17:48:49 bigip6400 alertd: 01100021:3: Couldn't process the /var/run/alert.conf: problems at line 408.
    Do you have a close curly brace on the alert definition?
            snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.12"}
    Aaron
  • Aaron,
    Thanks so much. That did it - I didn't even notice the missing trailing bracket.
    Matt
  • I have a script that pools this every minute for a given f5 and stores it in a new log file daily, would this be useful?...If so, I'll post.
