valve404's avatar
valve404
4 years ago
SNAT with client and pool member on same subnet
We have sort of an aut-last-hop feature on our firewall, and the lb is placed in front of the firewall. This ensures when a client from a random vlan behind the firewall connects to a VIP, the return traffic is actually sent back via the LB thanks to the 'auto last hop' like feature, and we gerally do not have to use snat.
But, when a client and the pool member is located in the same subnet, the firewall is not involved, and thus the client drops the return packet that comes directly from the server.
I would like to create a generic irule that would work in all vips, that compares client and pool member subnet.
The more I think about it, the more impossible it seems, since when executing the irule, the pool is not yet selected?
Is it possible to do this in an irule? Or do I need a separate irule for each VIP that will receive traffic where client && pool is on the same subnet?
Thanks for insights!
  • You could use it in the LB_Selected event and the LB::Server event
    https://clouddocs.f5.com/api/irules/LB__server.html
    https://clouddocs.f5.com/api/irules/snat.html
    there is a good starting point iRule that is liek this:
    # Apply SNAT automap for clients in the 10.10.10.0/24 subnet
    when CLIENT_ACCEPTED {
       if { [IP::addr [IP::local_addr] equals 10.10.10.0/24] }{
          snat automap
    And looking here for the iRule event order - it shows it should work https://clouddocs.f5.com/training/community/irules/html/class1/module1/iRuleEventsFlowHTTPS.html
    1. Create a SNAT pool and add SNAT Pool members to it.
    [SNATPOOL]
    ltm snatpool dmz1_snat {
    members {
    172.16.0.7
    172.16.0.8
    ltm snatpool dmz2_snat {
    members {
    172.16.1.7
    172.16.1.8
    2. Create a SNAT data group
    [ SNAT-DATAGROUP ]
    ltm data-group internal snat-dg {
    records {
    172.16.0.0/24 { dmz1_snat }
    172.16.1.0/24 { dmz2_snat }
    type ip
    3. Write iRule and apply it to virtual server
    when LB_SELECTED {
    if { [class match [LB::server addr] equals snat-dg] } {
    snatpool [class match -value [LB::server addr] equals snat-dg]
    snat automap
