mazek_59373's avatar
mazek_59373
Dec 04, 2008
snat - port usage monitoring
is there a way to check i SNAT automap/pool what is the usage of ports in translation?
regards
  • hoolio's avatar
    hoolio
    Are you trying to correlate client to VIP and SNAT to server connections? If so, you could use tcpdump and try to match up the connections by the source port. It should be the same for both connections. Or you could use an iRule to log the client and serverside connection details.
    Or are you concerned about SNAT port exhaustion? If so, the only method I know of is 'netstat -na| grep -c SNAT_IP'.
    Aaron
