Slow convergence between F5 Loadbalancer and Juniper router
Hi All,
We had configure BGP between Viprion and Juniper router. When the link was down or BGP was down the convergence was slow.
Juniper received routes from Viprion after the interval of 10-15 seconds. Pls confirm how we can resolve this issue.
BR//Suresh Joshi.
- IheartF5_45022
Nacreous
Can you be more explicit? What's your topology? I assume eBGP between viprion and router? Is there a redundant pairs of routers running iBGP between them? Are the Viprions active/active or active/standby?
Also can you be more explicit re failure conditions - Link down?
Please confirm all.
- Suresh_Joshi_01
We are using eBGP between Viprion and Router. Routers are in redundant pairs but we are not running iBGP between routers. Viprions are in active standby mode.
When the link between router and viprion is down failover is happening between viprions but router is receiving routes from viprion after 10-15 seconds.
- IheartF5_45022
Nacreous
I would run iBGP between your routers so that when failover occurs the 2nd router already has a routing entry with the necessary next-hop (the viprion floating self IP).
- aj1
Hi Suresh,
I am assuming you have a full-mesh between the Juniper routers and the Active/Standby Viprions. I have the same setup (no floating self-IPs). Are the routers able to detect which is the active unit and which one is the standby. When we used eBGP, the Junipers would still point to standby unit as the next-hop (when a failover occurred) to reach an internal host. Is there a way in BGP that lets the routers detect the active unit and change their next-hop accordingly in the event of a failover? Any help appreciated. Thanks!
