kridsana's avatar
kridsana
Apr 29, 2015
Simplify irule (rather than if ,elseif, elseif ...)
Hi
Is there anyway to simplify or condense this irule?
when HTTP_REQUEST
if {[HTTP::uri] starts_with "/atm/"
            or [HTTP::uri] contains "/ammcontent"
            or [HTTP::uri] contains "/htmlsite"
            or [HTTP::uri] contains "/publichtml"
            or [HTTP::uri] contains "/crmform"
            or [HTTP::uri] contains "/distsite"
            or [HTTP::uri] contains "/wttw"
            or [HTTP::uri] contains "/rules"
            or [HTTP::uri] contains "/attributeweb"
            or [HTTP::uri] contains "/contentweb"  }
                   {    pool atm_HTTP }
Thank you
  • we got many kind of irule. if we can simplify or condense it , it may help with much performance
  • And what problem if we using many "if" instead of if+elseif
    like,
    if {aaa}
    if {bbb}
    if {ccc}
  • I think you want something like:
    switch -glob [string tolower [HTTP::host]] {
        "/atm" {
            pool atm_HTTP
        "/ammcontent*" {
            pool atm_HTTP
    You can then future proof it by redirecting based on URI and adding new lines easily.
  • giltjr's avatar
    giltjr
        switch -glob [string tolower [HTTP::uri]] {
        "/ammcontent*" -
        "/htmlsite*" -
        "/publichtml*" -
        "/crmform*" -
        "/distsite*" -
        "/wttw*" -
        "/rules*" -
        "/attributeweb*" -
        "/contentweb*" } {pool atm_HTTP }
        default {pool default_pool }
  • Can I do like this?
    when HTTP_REQUEST
                or [class match [HTTP::uri] contains my_uri_datagroup] }
                      {    pool atm_HTTP }
    and my_uri_datagroup is include with all those uri "/.."
  • Hello Teepan,
    I hope this will work for you. Have you tried this ?
  • Arie's avatar
    Arie
    I would recommend converting the URL to lowercase before doing the comparison. Just make sure you always enter the values you want to check for in lowercase.
    So, instead of:
    You would use:
    if {[string tolower[HTTP::uri]] starts_with "/atm/"
    [class match [string tolower [HTTP::uri]] contains my_uri_datagroup] }
  • For scale-ability in the future if you ever needed to send traffic to other pools I would recommend creating your string data group with the URIs you want to match with values for the corresponding pool and use an iRule like this. I would also recommend setting the default pool on the virtual server itself.
        if {[string tolower [HTTP::uri]] starts_with "/atm/"}{
            pool atm_HTTP
        elseif {[class match [string tolower [HTTP::uri]] contains "/Common/my_uri_datagroup"]}{
            pool [class match -value [string tolower [HTTP::uri]] contains "/Common/my_uri_datagroup"]
