Angela_R_33237
Oct 19, 2005Simple iRule help (I hope) -- non-www to www.
How do I set up an iRule to redirect non-www requests to the www of that domain.
Example:
domain1.com --> www.domain1.com
domain2.com --> www.domain2.com
We have about 100 of these sites so ideally I'd like to be able to set up one iRule for all of them.
Any help is appreciated!
Angela
- Colin_Walker_12Historic F5 AccountYour rule would indeed be simple. It'd be something like:
when HTTP_REQUEST { if {[string tolower [HTTP::host] ] contains "www" } { pool your_poolname } else { HTTP::redirect "http://www.[HTTP::host][HTTP::uri]" } }
Hope this helps,
-Colin - Angela_R_33237
Wonderful -- thanks! This is what I ended up using:when HTTP_REQUEST { if { ([HTTP::host] starts_with "www.") } { pool pool_name } else { HTTP::redirect "http://www.[HTTP::host][HTTP::uri]" } }
Sorry, it's not very pretty. But it works -- thanks! - James_Ramsey_10
Why would you use this I-Rule and not just program this rule into the application? - Colin_Walker_12Historic F5 AccountOften times people find it beneficial to add logic like this to the network layer, rather than the application itself. Not only does it provide for greater flexibility in general, but it avoids needing to schedule a code-base change for your application, which for some peeople can be quite a process.
-Colin - James_Ramsey_10
Thanks, I didn't look at it that way. - JRahm
Admin
That's the message I've tried to preach at the last two companies I've worked for, the problem I've faced is the political machine. It's all about control, and the app developers want it all.
Something we are going to do as a network services shop is to do an internal "road show" to all of our application development teams, showing off what BigIP can do for, allow them to have an opportunity to make requests as to what they would like to hand off to the BigIP, and what hooks they would like to develop to shape traffic. This will hopefully bring down the wall and help them realize that the once distinct line between application and network is no more.
