Sideband connection - takes few seconds to get resonse
Hi, I've created the iRule that establishes sideband connection to make a decision what pool the original HTTP request to be sent according to the response data from the sideband virtual server. It takes ~3-5 seconds until the response from sideband VS came. If i simulate sideband HTTP request from, let say, my workstation using fiddler, the response has no delay.
Any idea what the problem could be?
Thanks Sergey
What is the timeout value you are setting in the connect string? The sideband connection will wait the timeout setting no matter if it only takes 30ms to receive the data. There is a solution to peek at the connection and return the data before the timeout value is reached. Search for "supersideband" in the wikis for iRule.
- R_Eastman_13667Historic F5 Account
