Bernard_9303's avatar
Bernard_9303
Mar 01, 2009
SharePoint redirection issue - iRules help needed
I have a issue with redirection on SharePoint on F5 LTM. Below is my current setup and problem that I face now. I'm doing SSL offloading on F5LTM.
On the F5 LTM, these are the settings:
Virtual server: sharept_vs_https
Pool: sharept_pool_https
Pool members: 10.10.0.80:443 and 10.10.0.81:443 (2 SharePoint Servers)
To access SharePoint Server, client needs to access this site:
https://sharept.hci.edu.sg
Problem:
When a client access https://sharept.hci.edu.sg, the Sharepoint server redirects the client to either http://10.10.0.80/sharept or http://10.10.0.80/sharept instead of https://shrept.hci.edu.sg.
Question:
How do I use iRules to to prevent such redirection or reverse the redirection caused by the SharePoint Servers?
Thanks,
Bernard
  • are you re-encrypting before sending traffic to the sharepoint servers?
  • Hi,
    Thanks for your reply...
    I'm terminating SSL on F5 LTM, traffic between F5 LTM and sharePoint Servers is unencrypted.
    Regards,
    Bernard
  • hoolio's avatar
    hoolio
    I think Sharepoint's method for configuring external host, port and/or URI aliases is to use Alternate Access Mappings:
    What every SharePoint administrator needs to know about Alternate Access Mappings (Part 1 of 3)
    http://blogs.msdn.com/sharepoint/archive/2007/03/06/what-every-sharepoint-administrator-needs-to-know-about-alternate-access-mappings-part-1.aspx (Click here)
    Plan alternate access mappings (Windows SharePoint Services)
    http://technet.microsoft.com/en-us/library/cc288609.aspx (Click here)
    I haven't tested this, but I'd be interested in hearing about your experiences if you try it.
    Aaron
  • Hi,
    I do heard from some people that iRules can be used to achieve the redirection, can anyone advise?
    Thanks,
    Bernard
  • hoolio's avatar
    hoolio
    Sure, it's possible to do this in an iRule, but it would be more efficient to have Sharepoint use the correct external alias in its references to itself.
    Take a look at this post and the rest of the thread for an example of how to do this with an iRule and indications from the past poster that changing the sharepoint configuration avoided the need for an iRule:
    Sharepoint 2007 Problem
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=30877&ptarget=30883 (Click here)
    Aaron
