Setting persistance for non-web based apps
I'm working on setting up a new profile for an app that runs on TCP104, and doesn't go over a browser (at least I don't think it does).
What are the best options for setting persistence on the VIP for setups like this? I have a feeling this will come up more in the future.
- Vijay_E
Cirrus
IP persistence appears to be the simplest option. You can try to write an iRule for persistence based out of incoming packet information.
- stan_piron
Cumulonimbus
Persistence must be set to force a session over multiple tcp connections to stay on the same server!
If you don’t know how the application works, are you sure you require persistence?
Does a session is created over multiple tcp connections?
