AP_129594
Sep 03, 2014Setting iRule from CLI
I need to schedule a task that required to add 2 iRules back into a virtual. Can somebody help me with the syntax?
tmsh virtual rules { rule1 } && { rule2 }
- AP_129594
tmsh modify ltm virtual my_virtual rules { rule1 } && { rule2 } - nitass
Employee
there is no add option, so you have to put all the irules.
e.g.
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.24.10:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } tcp { } } source 0.0.0.0/0 source-address-translation { type automap } vs-index 7 } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) modify ltm virtual bar rules { qux quux } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.24.10:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } tcp { } } rules { qux quux } source 0.0.0.0/0 source-address-translation { type automap } vs-index 7 } - AP_129594
thanks a bunch...just a space between the 2 rules :)
