session refresh with iControl ... not work
I am trying to write command line interface to some features of my F5 ... with authorization via cookie file (username and password should be given only once (per ~ 10 hours)) Authorization with cookie file works fine ... until something wrong happens with my session.
For the first time I am authenticating traditionally, with given username and password:
eval {
my $soap = SOAP::Lite->new(
'proxy' => [
"https://" . $CONFIG{'F5_HOST'} . ":" . $CONFIG{'F5_PORT'} . "/iControl/iControlPortal.cgi",
'credentials' => [
$CONFIG{'F5_HOST'} . ":" . $CONFIG{'F5_PORT'},
"BIG-IP",
$CONFIG{'F5_USER'}, clear text username
$PASSWORD,
cookie_jar=>HTTP::Cookies->new(ignore_discard => 1, file=>$CookieFile, autosave=>1 ),
Cookie file saved on disk looks as follow:
$ cat $CookieFile
LWP-Cookies-1.0
Set-Cookie3: BIGIPAuthCookie=71C*************************************; path="/"; domain=**.**.***.***; path_spec; secure; discard; version=0
Set-Cookie3: BIGIPAuthUsernameCookie=*******; path="/"; domain=**.**.***.***; path_spec; secure; discard; version=0
... "for some time" I do not have to give username and password, this credentials are READ from file "path_to_my_cookie_file":
eval {
'proxy' => [
and then get_failover_state() from 'uri' => 'urn:iControl:System/Failover'.
...this works ... for some about of 20 minutes (and this time varies! not always 20min, why?) and then ... cookie is not valid, I am getting: "401 F5 Authorization Required" and I have to type username and password 😞
When I am using F5 with web browser my session is kept longer without any ask for password.
How to keep my session (in many hours) via iControl ? F5 limits concurent session to 10, how to work with that and keeping session ?
