Serial Cable Discovery
I have two HA pairs of LTM. is there any command/way so i can check they are connect via serial cable or not.
- Ajmal_2608
What version you are on?
In 10.x
b failover cable
In v11.x
tmsh show sys failover cable
Displays the status that the failover daemon detects on the serial
cable from its failover peer. It also shows what the failover peer
detects on the serial cable. An active BIG-IP will see a zero from its
failover peer. A standby BIG-IP will see a one from its failover peer.
The output will be:
On Active unit - cable state 0
On Standby unit - cable state 1
If it gives some thing like cable state unset or some error then failover cable is not connected properly
- VSE_113287
what does it mean if on both appliance (active and standby unit) the cable state is "0" And how to check whether the failover port is disabled or enabled? is there a command line to verify that?
