Ivan_Markovic_3's avatar
Ivan_Markovic_3
Sep 14, 2012
Self IP config-sync problem
Hello everyone,
I'm new to this device and have a problem. The administrator before me make Self IP address to point to some adress that is now Gateway on this new network. When I try to delete it I get this error:
01071412:3: Cannot delete IP (192.168.XXX.XXX) because it is used by the system config-sync setting.
I have MGMT access only to Web interface. Do you have some advice for me? How to change this settings? I can not change Gateway address ...
Thanks!
Ivan
  • Hamish's avatar
    Hamish
    Hi. On that unit, goto device management, select the (self) device and then goto the config-sync tab.. Then just change he config-sync to another interface. You can then delete the selfip.
    H
