StanI_87551's avatar
StanI_87551
Aug 28, 2015
second pool iRule for Maintenance page
I have attempted to create an iRule that moves traffic from one pool to a Maint-Page pool when the members of the Production pool are "down". Each server in the Production pool (prf1.aviallinc.com-ssl) has a Health Monitor which so when the health monitor reports the servers down the iRule should move traffic to the Maint-Pool (sorry_ssl).
But, nothing happens.
Local Traffic ›› iRules : iRule List ›› tst2-sorry_ssl Partition / PathCommon
when HTTP_REQUEST { if { [active_members "/Common/prf1.aviallinc.com"] < 1}{ pool "/Common/tst2-sorry.aviall.com-ssl" return } }
I feel certain I have failed with my syntax BTW: I have tried with and without "
BIG-IP 11.5.1 Build 5.0.147 Hotfix HF5
Stan
  • Did you check that the irule is applied to the correct VS? Also try a log statement to test...
    cheers
      if { [active_members /Common/prf1.aviallinc.com] < 1 } {
        pool /Common/tst2-sorry.aviall.com-ssl
        log local0. "Sending to maintenance page.."
