Mike_Tr_143964's avatar
Mike_Tr_143964
8 years ago
Script to switch between two pool members.
Has anyone written a script to switch pool members state? Switch the enable member to disable and the disabled member to enable in a 2 member pool. We are not running active/active so the disabled member would need to be brought up first. Thanks. Mike.
  • You could control status of pool members based on healthcheck strings. Or, out-of-band using API calls. What is it that you are trying to achieve?
