Waynengi's avatar
Waynengi
Jan 19, 2018
Script to add SNMP and Trap setings?
Is there a script that can be run via tmsh to add SNMP and Trap settings?
  • I was looking more towards adding SNMP Trap destinations with its community strings. I have 5 IP's to add and wanted to make it easier. Is there something that i can run instead of doing it via GUI.
  • you can probably do something directly in the config files or export and import via tmsh load sys config merge or such.
