emiliocb4_27077's avatar
emiliocb4_27077
May 11, 2011
scan problem
hi all,
follow is a part of my irule
set valore "*gtw1"
scan $valore %s%s primo secondo
log local0.debug " primo= $primo secondo= $secondo"
set valore1 "* gtw1"
scan $valore1 %s%s terzo quarto
log local0.debug " terzo= $terzo quarto= $quarto"
the first one doesn't work, the secondo one works.
how can i set as separator?
i tried to use ^ or or "^" or "" but none works
can u help me??
  • hoolio's avatar
    hoolio
    Hi Emilio,
    The problem is that everything but a space (or other whitespace) will be matched with %s:
    http://www.tcl.tk/man/tcl8.4/TclCmd/scan.htmM12
    So you'd need to be able to specify a character class that doesn't include the in order to use scan for the first string. If you just want to split the string on a specific character you can use getfield or split instead:
    http://devcentral.f5.com/wiki/default.aspx/iRules/getfield
    http://www.tcl.tk/man/tcl8.4/TclCmd/split.htm
    If neither of those options work, can you give more detail on what you're trying to parse? The more examples, the better.
    Aaron
