SAML Authentication from iOS Edge Client
I was wondering whether anyone has had any success using SAML authentication for iOS Edge Client access?
I am using iOS Edge Client 2.0.9. The release notes for 2.0.3 announced that SAML authentication had been added for SP-initiated connections using the Web Logon mode.
I am able to trigger SAML authentication within the APM policy when the Edge Client connects, but once successfully authenticated against the IdP via the web-logon, an assertion fails to arrive.
If anyone has been able to get this working it would at least help me to know where to focus my debugging efforts.
Thanks,
Barny
Barny,
That should definitely work, so I suggest you open a support case and ask them to investigate this for you.
