Routing behavior for requests coming in one interface but sourced from an IP on another interface
Say I have a load balancer with the following interfaces: VLAN 1 : 192.168.1.1/24 VLAN 2 : 192.168.2.1/24 VLAN 3 : 192.168.3.1/24
I have a virtual server on the same subnet as VLAN 1 with pool members on VLAN 2. Now say the hosts that exist on the same subnet as VLAN 3 have a gateway that is not the load balancer and the requests to the virtual server from these hosts are routed back around to the VLAN 1 interface through some other route.
Does the load balancer recognize that the source is on the same subnet as its VLAN 3 self-IP and route it directly out that interface or will it try to go back out the VLAN 1 interface?
Assume the default route points out the VLAN 1 interface and that source autonat is configured for the virtual server.
Thank you!
i understand return traffic will be sent via vlan1.
sol13876: Overview of the Auto Last Hop setting (11.x)
http://support.f5.com/kb/en-us/solutions/public/13000/800/sol13876.html
- nitass
Employee
http://support.f5.com/kb/en-us/solutions/public/13000/800/sol13876.html- LA-Engineer_160
Thank you! Thats where I saw it from. I forgot what feature it was called.
- nitass_89166
Noctilucent
