Routing / SelfIP question
Hi all,
What determines the source address of a monitoring packet on an LTM where I have multiple VLAN's and relative SelfIP's (one per VLAN) ?
I assume (from my observations) it is the selfip associated with the VLAN of egress, am I right?
I ask because I am observing monitoring packets for four nodes on the same network egressing the same VLAN (default route) where in the case of one of the four nodes the source address is a selfip for a completely different VLAN.
Anyone ever seen behavior like this?
- Jason_Keating
Altostratus
Just got the opportunity to do a 'bigstart restart' - its now using the correct selfip.
Go figure !
FYI I am running
BIG-IP Version 10.2.0 1755.1
Hotfix HF1 Edition - Chris_Miller
Altostratus
Should always be the self-ip of the vlan facing it. Did you by any chance add a self-ip while there were existing connections? - Jason_Keating
Altostratus
It's possible I did, I assume thats problematic so will avoid it in future.
Jason - Chris_Miller
Altostratus
Posted By Jason Keating on 11/08/2010 01:58 AM
Jason
Not so much problematic as a "gotcha." You'll run into this when creating new Virtual Servers, SNATs, etc. You simply need to use "b conn delete" to delete connections that were already using your old settings.
