Route Domains, strict isolation and parent
I wonder if my understanding (based on Working with Route Domains) of Strict Isolation (SI) and Parent settings is correct.
Scenario:
RD0 - default in Common, SI enabled
RD1 - (in Common) SI Enbled, Parent set to 0
RD2 - (in Common) SI Enbled, Parent set to None
VS created in RD0 (VIP), pool members from both RD0 and RD1 - traffic should be forwarded to both pool members because of Parent/Child relationship
VS created in RD2 (VIP%2) - pool members from both RD0 and RD2 - traffic should not be forwarded to member from RD0 because there is no Parent/Child relationship
VS created in RD1 (VIP%1) - pool members from both RD1 and RD2 - traffic should not be forwarded to member from RD2 because there is no Parent/Child relationship and SI is enabled, in case SI would be enabled on both RD1 and RD2 traffic should be forwarded to both pool members
Is above correct? If there is Parent/Child relationship SI setting can be enabled and still traffic will be routed between RDs?
Piotr
- Brad_Parker
Cirrus
- Yes
- Yes
- Yes, No. If you created a VIP in RD1 and have SI turned on only pool members in RD1 could be reached. If you turned off SI for both, then pool members in RD1 and RD2 could receive traffic.
If there is a parent/child relationship and SI is enabled traffic can still pass between the two route domains. I believe routes in the child domain will take precedence over the parent if there is overlap.
- dragonflymr
Well, for 3. I just made mistake, should be " in case SI would be disabled on both RD1 and RD2", so I assume Yes, Yes :-) Thanks a lot for clarification. Piotr - Brad_Parker
Cirrus
you are welcome.
- Brad_Parker_139
Nacreous
- Yes
- Yes
- dragonflymr
Well, for 3. I just made mistake, should be " in case SI would be disabled on both RD1 and RD2", so I assume Yes, Yes :-) Thanks a lot for clarification. Piotr - Brad_Parker_139
Nacreous
you are welcome.
