RFC2616 - content-disposition with special characters - Problem to export file
Hello people.
I have one problem
I am having problems to export a excel file, bigger than 96K. When the file is smaller than 96K the problem dosent occurs, but with files bigger than 96K the F5 send a reset packet.
In SOL5922 : Error Message: http_process_state_prepend - Invalid action EV_INGRESS_DATA during ST_HTTP_PREPEND_HEADERS
I identificated this erros, The sol said that Any response that is not compliant with RFC2616 causes this error message.
In a Httpwatch a can see that in content-disposition there is special characteres like example:
content-disposition= attachement;filename=FILE_teste_01/01/2001 10:08:01.xlsx;size=196...
Probably these special characters in content that is not compliant with RFC2616.
if that behavior can not be corrected the application side, can I solve that with some irule? irule Replace content can resolve? If someone can quote some example that would answer thank you very much
thank you very much
- nitass
Employee
have you tried to log rst cause? just wondering which cause will be logged.
sol13223: Configuring the BIG-IP system to log TCP RST packets
http://support.f5.com/kb/en-us/solutions/public/13000/200/sol13223.html
- F5userBR_162793
Hello
The cause of the problem, is like the SOL said, a back end answer that not compliance with the RCF.
We are analyzing the tcpdump captures and httpwatch.
Until this moment we identify one beahvior. content-disposition there is special characteres like example:
thank you very much
- Lucas_Thompson_Historic F5 Account
You can turn off HTTP processing altogether by either removing the HTTP profile from the virtual or using the HTTP::disable command in an irule after connecting to that server.
https://devcentral.f5.com/wiki/iRules.http__disable.ashx
- F5userBR_162793
Thompson but my Vs use http profile and cook persistence. I cant remove then
- F5userBR_162793
In my scenario I have no irule.
Only a VS with http profile and cookie persistence
- F5userBR_162793
if that behavior can not be corrected the application side, can I solve that with some irule? irule Replace content can resolve? The Vs use http profile and cook persistence.
thanks a lot
