ReverseProxy Configuration Error - Need Help
I am deploying a reverse proxy, I have been following the guide from the manual: "BIG-IP_Local_Traffic_Manager" (Chapter 24 Configuring the BIG-IP System as a Reverse Proxy Server)
The step i am having trouble with is: Creating a local traffic policy
Basically the problem is that i have to asociate two http-uri with one original address to execute the translation however, when i am finish configuring the policy i got errors:
If i try to include the both conditions inside the same policy i got: 010716d8:3: Compilation of ltm policies for virtual server /Common/vs_sugar_crm_reverseproxy_80 failed; Failed to compile the combined policies. (reverse policy.jpg, reverse policy2.jpg)
otherwise if i try to create two policies, and associate them with the virtual server, then: 010716fd:3: Virtual Server '/Common/vs_sugar_crm_reverseproxy_80' cannot contain policies with conflicting controls.
I don't know what i have missing; how to correctly configure a policy with the both conditions, because the second option clearly doesn't work, so if any one could help me to figure it out, would be grate.
- Jorge_Herran_14
Altostratus
I have now start irule aproximation, this is what i am doing, however it isn't working yet:
when CLIENT_ACCEPTED {
set default_pool [LB::server pool]} when HTTP_REQUEST {
switch [string tolower [HTTP::uri]] { "/consulta_bancolombia" { HTTP::uri "/pruebas/consulta_bancolombia/" pool pool_sugar_crm_reverseproxy_80 } "/crm_calidad" { HTTP::uri "/pruebas/crm_calidad/" pool pool_sugar_crm2_reverseproxy_80 } }}
i think my problem is just something related to syntax, please make comments over my mistakes.
- stan_piron
Cumulonimbus
Your 2 solution were wrong.
- Action "forward pool" must be unique
- 2 Policies with same "controls" cannot be assigned to the same VS
the solution is: create one policy with 2 rules...
- Jorge_Herran_14
Altostratus
i finally solved just with this syntax:
when CLIENT_ACCEPTED { Save the name of the VS default pool set default_pool [LB::server pool] } when HTTP_REQUEST { Check the requested path with wildcard matching switch -glob [HTTP::path] {
"/pruebas/consulta_bancolombia*" { /consulta_bancolombia URI pool pool_sugar_crm_reverseproxy_80 } "/pruebas/crm_calidad*" { /crm_calidad URI pool pool_sugar_crm2_reverseproxy_80 } default { non-/pruebas* URI pool $default_pool }} }
No matter if someone know how to use the profile config to achieve the same result would be great to know.
