Retrieve SyncStatus of device using iControl
I want to retrieve the sync status of a particular device using Icontrol.dll. I found the following functions and ran it in powershell and get the following error, 1. $interface.ManagementDeviceGroup.get_device_sync_status("grpname","devicename") Exception calling "get_device_sync_status" with "2" argument(s): "Unknown method "{urn:iControl:Management/DeviceGroup}:get_device_sync_status""... 2. $interface.ManagementDeviceGroup.get_sync_status("grpName") Exception calling "get_sync_status" with "1" argument(s): "Unknown method "{urn:iControl:Management/DeviceGroup}:get_sync_status""
Can anyone please help me resolve this error. Thank you.
Hi! Have you upgraded the pssnapin module?
The method you refer to came in v11.4.0 and the snapin module was updated 1 month ago.
/Patrik
I tried it with my current version and it failed. Then I updated to the latest one and it worked, so that seems to be your problem as well.
/Patrik
- maggie_129843
Hi Patrick,
Thanks for your response. I verified that it was with the version we use. - Dll version is 11.4 while the bigip is 11.3. Is there any other way to get the sync status or any other work around? Thanks!
That explains a lot. :)
Sorry, but I don't know any other way to programmatically do it via iControl.
I guess you could login to the web interface with powershell and parse it from the code if you login with System.Net.WebClient and extract the string between:
"[a href="/tmui/Control/jspmap/tmui/devmgmt/overview.jsp"]" and "[/a]"
Had to replace the tags with brackets. The forum does not like them.
/Patrik
- maggie_129843
Thanks! We had tried that as well and found the request URL for sync but somehow not able to login using the user id and pwd using powershells': Invoke-WebRequest, System.Net.WebClient
Thanks,
So you've tried something like this?
http://www.powershellcookbook.com/recipe/vODQ/script-a-web-application-session
/Patrik
