CraigMo's avatar
CraigMo
Jul 21, 2010
Restore to 9.3.1
I was wondering if anyone had a document or steps/process involved in restoring to 9.3.1 (partitions) from 10.0.1 (volumes). Thanks,
  • hoolio's avatar
    hoolio
    Hi Craig,
    One process that should work is to burn or mount the 9.3.1 ISO and boot a computer (or VM image) with it to act as a PXE server. Connect the PXE server and LTM management IP via a switch or using a cross over cable. Then set the unit to netboot using the SCCP (ssh sccp; run hostconsh; select option 4 - netboot, 7 - reset host, Y - confirm, 1 - connect to host).
    You can find more info on AskF5 by searching for LTM related articles and the term "downgrade". Here's one solution:
    SOL7473: Downgrading BIG-IP LTM, GTM, Link Controller, or ASM software
    https://support.f5.com/kb/en-us/solutions/public/7000/400/sol7473.html?sr=9037253
    Aaron
