stuart_weinstei
Jan 10, 2012resources on same VLAN
As I am new to F5 LTM, have ACE and CSS experience, I am in need of some guidance on the best way to handle the flow of traffic as follows
Nodes in the pool are in VLAN X, web services, that need to access DB server in the same VLAN X.
As I understand it, assuming I am, I could do a snat using the IP of the VIP or an Irule if i have it right)
when CLIENT_ACCEPTED {
if { [IP::addr [IP::client_addr] equals x.x.x.x/bit mask }{
snat automap
Is the above correct? is there a better way?
Thanks in advance
- hoolio
Hi Stuart,
If all clients are on the same subnet as the servers being load balanced, you could just enable SNAT on the virtual server (either automap or an explicit pool) without using an iRule. Else, you could use that iRule if you only want to apply SNAT for a specific subnet(s). Here's an option for using SNAT only when the client and server are on the same subnet:
http://devcentral.f5.com/wiki/iRules.SelectiveSNAT.ashx
Aaron - Colin_Walker_12Historic F5 AccountAaron's right, you don't need an iRule for this and would likely be better served without one. But just in case you try your iRule, you're missing a bracket π
when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals x.x.x.x/bit mask] }{ snat automap } }
Colin (The pedantic coder)
