aries_232853's avatar
aries_232853
8 years ago
Reset all configuration to default except bigip_base.conf
Hi everyone,
Is there a way I can reset the configuration of my vCMP guest but still retain its network and HA configuration?
I've read this article: https://support.f5.com/csp/article/K6887 but I'm not sure if this still works on the new versions (v11 and v12?
Many thanks!
  • I dont recall there's one for 11.x. When you run
    tmsh load sys config default
    , it wipes out every configuration and sets it to factory default setting.
    In order to have default bigip.conf, I'd try the below setups.
    Pre-requisite, you should have a fresh bigip.conf file.
    1. Have a ucs backup taken.
      tmsh save sys ucs /var/tmp/before_reset.ucs
    2. Have a original bigip.conf backup taken.
      cp /config/bigip.conf /var/tmp/before-reset-bigip.conf
    3. Have the fresh bigip.conf file moved to /config/bigip.conf
      cp /var/tmp/fresh-bigip.conf /config/bigip.conf
    4. Load the config, in this way, your network settings are intact and you have a fresh bigip.conf
    In the event there's no fresh bigip.conf file, I would just take UCS backup, reset it to default. Now I have fresh bigip.conf file. I would take a copy of this and load the original UCS again and put back this fresh bigip.conf file and load the config.
    3. Reset to factory setting.
    4. Have the fresh bigip.conf file moved to /var/tmp/bigip.conf
      cp /config/bigip.conf /var/tmp/fresh-bigip.conf
    5. Load the original UCS back again, in this way your network settings are again loaded.
      tmsh load sys ucs /var/tmp/before_reset.ucs
    6. Now that you have fresh bigip.conf file in the temp folder, move it back and load the config.
    7. Load the config.
    Do wait for others to comment on their methods. If there's any easy approach, you can try that.
  • fairly sure you can just load bigip_base.conf and it will re-load the base file and not bigip.conf.
  • Hi jaikumar_f5 and MrPlastic, thank you for the suggestions!
    Unfortunately, prior to resetting the config to default, we already had an error for
    . Due to this error,
    also did not work.
    F5 support suggested we run:
    mv /config/bigip.conf /config/bigip.conf.old
    then proceed with loading bigip_base.conf.
    Thank you for the help guys!
