Ivan_38381's avatar
Ivan_38381
May 11, 2009
Replace Secondary Unit
What is the best method to replace the faulty unit in HA environment.
I'm planning to - Re-ip & cofigure failover and Sync ..
Any other alternatives please....
  • You need to either consult F5 support or use go the following Ask.f5.com support knowledge base link
    https://support.f5.com/kb/en-us/solutions/public/8000/000/sol8086.html
    I hope this helps
    CB
  • As an alternative for step 7 on SOL8086 from CB, if the faulty unit is still accessible, transfer /config/bigip_base.conf to the new unit and do ConfigSync.
    CMIIW ...
