ukitsysadmin_95's avatar
ukitsysadmin_95
Nov 10, 2009
replace http::host headers
Is it possible to do the following
if { [HTTP::host] starts_with "preview.www."} {
I want to redirect to
HTTP::redirect "http://preview2.www."same domain name"
but I keep getting
preview2.www.preview.www.abc.com
We have hundreds/thousands of domain names and growing, example
abc.com
def.com
ghi.com
because the growing number of domains
I want the irule just to replace, preview.www."domain name" with preview2.www."same domain name"
so no matter what domain name I type preview.www.abc.co.uk or com or be etc, etc it will redirect to preview2.www.abc.co.uk or com or be etc, etc
type:
preview.www."any domain name" redirect to preview2.www."same domain name"
Hope this make sense ?
  • hoolio's avatar
    hoolio
    You can use the domain command to parse the domain from the HTTP::host value:
    http://devcentral.f5.com/Wiki/default.aspx/iRules/domain
        log local0. "[IP::client_addr]:[TCP::client_port]: New [HTTP::method] request to [HTTP::host][HTTP::uri]"
        if { [string tolower [HTTP::host]] starts_with "preview.www."} {
           log local0. "[IP::client_addr]:[TCP::client_port]: Redirecting to http://preview2.www.[domain [HTTP::host] 2]"
           HTTP::redirect "http://preview2.www.[domain [HTTP::host] 2]"
    Aaron
  • hoolio's avatar
    hoolio
    Actually, the domain command won't work for this scenario if you need to support example.com and example.co.uk...
    How about this instead:
            log local0. "[IP::client_addr]:[TCP::client_port]: Redirecting to preview2.www.[getfield [string tolower [HTTP::host]] preview.www. 2]"
            HTTP::redirect "http://preview2.www.[getfield [string tolower [HTTP::host]] preview.www. 2]"
    Aaron
  • Thats excellent thank you,
    is it possible to keep the orginal url in the browser ?
    although preview.www. has redirected to preview2.www can the broswer still say preview.www."any domain name"
