SysTopher's avatar
SysTopher
Sep 28, 2016
Removing a character from a variable using TCL
Hello,
iRule newbie here. I'm curious if anyone can give me an idea of how I could take a variable and strip out specific characters. For example, I have an iRule where I'm pulling a variable, such as [ACCESS::session data get "session.custom.variable"] and I want to remove an @ sign if it exists in this variable.
Perhaps I could even grab this variable and create a new variable? It's being used in an APM policy, so I would be find doing a variable assign where I get this variable, manipulate it to remove any @ symbol and place it into a new variable and then call this new variable in my iRule.
Any tips that any TCL experts can assist me with?
Thank you
  • set variable [ACCESS::session data get "session.custom.variable"]
    set newVariable [string trim $variable "@"]
    Keep in mind this will remove all @ from $variable, regardless of location in the string.
    • ekaleido's avatar
      ekaleido
      Icon for Cirrus rankCirrus
      Or I suppose you could just
      set variable [string trim [ACCESS::session data get "session.custom.variable"] "@"]
    • SysTopher's avatar
      SysTopher
      Ekalieido,
      This looks like it would work great, but it turns out the APM option that Kai suggested works better with my existing variable assign so I marked his response as the acceptable answer for my case. Unfortunately I can't mark both of you as correct, but for anyone else reading this looking for a similar solution please keep in mind that both of these answers are great suggestions.
    • ekaleido's avatar
      ekaleido
      No worries! Just glad you were able to get it done.
    • ekaleido_26616's avatar
      ekaleido_26616
      SysTopher
      Ekalieido,
