Lapsio
Altostratus
Nov 21, 2018Remove vs type field (eg. ip-forward or l2-forward) using TMSH?
I'm trying to get around tmsh config editing. I made following standard test vs:
destination 192.168.2.0:any
mask 255.255.255.0
profiles replace-all-with {
ipother{}
source 0.0.0.0/0
translate-address disabled
translate-port disabled
Then I modified vs using tmsh by adding
l2-forward field:
l2-forward
mask 255.255.255.0
ipother{}
source 0.0.0.0/0
And now I'm unable to remove this field. When I use
edit command, remove this line and save - nothing happens. I can't seem to use delete command on this field (delete ltm virtual test l2-forwarding) either because it says that l2-forward is read only property. So how can I remove this field from vs using tmsh? GUI allows to change vs type to standard and such operation removes this line from config but I don't know how to achieve this using tmsh1 Reply
- rob_carr
Cirrocumulus
It appears (in v13.1.0.7) that once you pick a specific type of virtual server, you cannot convert that virtual server to a standard virtual server via TMSH. You can change it from one specific type to another (e.g. l2-forward can be changed to ip-forward), but there is no obvious way to change back to a standard virtual server.
