CSA's avatar
CSA
Feb 17, 2009
Redirections HTTP to HTTPS (for login) to HTTP (for usage)
Hello all,
We use BigIPs for many applications used over a WAN. Our WAN has some boxes to compress/accelerate HTTP traffic, but they can't do it with HTTPS. We don't want to send the login/password in clear text over the network, so we want to use HTTPS for this.
So we would like to use the BigIPs like this :
- if someone use http (and is not logged in), redirect him to https
- each time someone has to authenticate, https is compulsory.
- once the authentication is done, use HTTP
What is the best way to do this ?
Is it this one :
- irule to redirect http to https when the application shows the login page (it shows it each time the user wants to load a protected page : this is handled by the application itself)
- irule to redirect https to http when it's not the login page (meaning the user is already authenticated from an application point of view)
Is there a smarter way ? Is it ok or the BigIP session mechanism ?
And second question : some applications just change the content to ask for the credentials, but the page name can be anything: is it possible to check in the content of the page for some strings and are the ressources used to do this acceptable ?
Thanks !
LB
  • We ran into this very issue several years ago. This is where we did not want to spend the extra $$ for a module on the BIGIP. The problem we encoutered was that the BIGIP didn't know when a client had successfuly logged in. So we decided that once the login page successfully authorized, the client is redirected the client over to HTTP.
    So yes we found a solution, but it wasn't a bigip solution
    As for your second question if you refering to monitoring then use you can monitor for strings in a page which is a common technique to use.
    Hope that helps
    CB
  • Hello Bhattman,
    I would sincerely appreciate if you could please post how you implemented the solution. We have exactly the same situaion posted by LB.
    Regards,
    qcontinuum
  • Our core application design team had a Siteminder license which allowed them to anthenticate via HTTPS but then redirected them over to HTTP.
    Bhattman
  • Guys,
    I have similar issues, we have created a HTTPS health monitor and we are using the username and password to login onto the server. However, we can only use a corporate domain account with the COMPANY\username prefix. We woudl like to use a local server username and password validate. Is this possible?
    Thanks!
    Just to add:
    SOL5483: Testing an HTTPS Monitor with user authentication from the command line
    https://support.f5.com/kb/en-us/solutions/public/5000/400/sol5483.html?sr=10763589
    HTTPS Monitor definitions will appear similar to the following example:
    monitor ssl_test {
    type https
    use "https"
    interval 5
    timeout 16
    dest *:*
    send "GET /testpage.asp HTTP/1.0\nAuthorization: Basic dGVzdHVzZXI6dGVzdHBhc3N3b3Jk\n"
    recv "matchthis"
    username "testuser" <-----< missing company\
    password "testpassword"
    Here's another SOL, but needs APM, which we dont have:
    SOL11446: Overview of HTTP authentication
    https://support.f5.com/kb/en-us/solutions/public/11000/400/sol11446.html?sr=10763589
    Hope to hear you ideas. Thanks!
  • hoolio's avatar
    hoolio
    Hi Raj,
    Can you change the send string to include the domain\ as part of the base64 encoded user:pass and remove the username and password field values from the monitor definition?
    Send string:
    GET /testpage.asp HTTP/1.0\r\nAuthorization: Basic RE9NQUlOXHRlc3R1c2VyOnRlc3RwYXNzd29yZA==\r\n\r\n
    where RE9NQUlOXHRlc3R1c2VyOnRlc3RwYXNzd29yZA== is the base64 encoding of DOMAIN\testuser:testpassword
    Also, here is a solution related to the \r\n's at the end of the send string:
    SOL10655: Change in Behavior: CR/LF characters appended to the HTTP monitor Send string
    http://support.f5.com/kb/en-us/solutions/public/10000/600/sol10655.html
    Aaron
