yukselkarapinar's avatar
yukselkarapinar
Aug 08, 2018
Redirection irule for https and Rewrite issue
I need help for an irule or a policy,
domain is def.local rewrite there should be rewrite such as /test-web or /Test/?locale=tr redirection only /test-web/updater will work on http all other abc.def.local request should be (https) and /test-web should be rewrite end of the url
for example when clients go to the aa.def.local there should be redirection and rewrite such as
(aaa.def.local/hbys-web/updater) (bbb.def.local/hbys-web) (ccc.def.local/AkRIS/locale-tr)
  • Your question seems a bit vague. If a client makes a request to aa.def.local, which address should the request be redirected to ?
  • Hi, thank you for your response, this work only for redirection http to https. I m trying to make rewrite and redirection at the same time.
