Redirect with URI rewrite setting lowercase URI and removing trailing /
I am after some assistance. Essentially I have the requirement to change the URI which is passed to the server. i.e. client requests /content/content server gets /site/path/content/content so this appears to work OK I am using IRULE for the request and the response is being re-written with a rewrite profile (stream works too).
The site server side is all lower case I then had a request to change any case to lower as its sent to the server and also remove the trailing '/'. So the logic I have below works fine for this however if you request '/content/cOntent/' this is whats displayed in the browser address bar however the requirements are to display '/content/content'
So I am assuming a redirect is needed to achieve this however i have been have problems making the redirect work but still sending the additional path to the server. The working IRULE without the redirect is below. Is it possible I can get some assistance on how to combine a redirect with server URI rewrite?
if {[string tolower [HTTP::uri]] starts_with "/" } {
set sitepath [string tolower [HTTP::uri]]
HTTP::uri "/site/path$sitepath"
if { [HTTP::uri] ends_with "/" } {
HTTP::uri [string trimright [HTTP::uri] "/"]
Thanks in Advance.
- Faruk_AYDIN
Altostratus
Hi Guy,
Try this iRule:when HTTP_REQUEST { if {[string tolower [HTTP::uri]] ne [HTTP::uri] && [string tolower [HTTP::uri]] starts_with "/content/"} { HTTP::redirect "/site/path[HTTP::uri]" } if { [HTTP::uri] ends_with "/" } { HTTP::uri [string trimright [HTTP::uri] "/"] } } - stan_piron
Cumulonimbus
this irule may cause some issues...
if you want to remove ending /, how do you manage URI
?/And in HTTP, URI ending with a / is not the same as URI without /. are you sure of the application behavior if you remove it?
- Henrik_Gyllkran
How about this:
when HTTP_REQUEST { set sitepath [string tolower [HTTP::uri]] if { $sitepath ne [HTTP::uri] }{ The lower case URI differs from HTTP::uri i.e. the HTTP::uri contains upper case characters HTTP::redirect $sitepath } elseif {[HTTP::uri] starts_with "/" } { HTTP::uri "/site/path$sitepath" } if { [HTTP::uri] ends_with "/" } { HTTP::uri [string trimright [HTTP::uri] "/"] } } - stan_piron
Cumulonimbus
you can try this code:
when HTTP_REQUEST { Convert path to lowercase and remove first and last /. prepend a / (to prevent "/" removed) use path instead of uri to prevent query string blocking path transformation. the general behavior when converting to lower case is to keep query string case set new_path "/[string trim [string tolower [HTTP::path]] "/"]" Add /site/path if starting with /content if {$new_path starts_with "/content/"} { set new_path "/site/path$new_uri" } Append query string if exists if {[HTTP::query] ne ""} {set new_uri $new_path?[HTTP::query]} else {set new_uri $new_path} if { $new_uri ne [HTTP::uri] } { if the new path is different to request path, redirect to new uri HTTP::redirect $new_uri } }
