Redirect [url:port] WAN for [url:port] LAN - iRules
Good afternoon people.
I have an application published on the web, which accounts for DNS.
This application to be opened, runs on port 81. So, to access the application on the Internet, have to put the Url and door to run.
Ex. Url1.algumacoisa.com:81
The Vs and the server, respond on port 81.
I need to do the following. The User to access the application not put the door in the url, and BigIP is a redirect to the Vs correctly with the included port, as follows.
By accessing the application, both internal and external, when you type in the browser url1.algumacoisa.com the BigIP does redirect to the Vs correctly to url1.algumacoisa.com:81.
I need that door is transparent to the User, without his having to type in the URL.
It is possible to make a iRules that?
- Yann_Desmarest_
Nacreous
If I understand correctly, you may need an irule like below :
when HTTP_REQUEST { if { [HTTP::host] eq "url1.algumacoisa.com" } { HTTP::respond 302 Location "http://url1.algumacoisa.com:81[HTTP::uri]" } }Good afternoon. I took the test, but still did not work!
it would help if you explain what happens which you didn't want to and how you would like it to work.
- Vijay_E
Cirrus
In this case, you won't need the ":81"
- You need to configure your VS to listen on port 80.
- Pool members need to listen on port 81.
