AngryCat_52750's avatar
AngryCat_52750
Dec 02, 2013
redirect out of a frame
we have an application spits out a specific URI that i need to redirect to a seperate page.. i got the redirect part to work but its stuck within a frame.. is there a way to have it "redirect outside of the frame" and to the redirected page??
    if {([string tolower [HTTP::uri]] starts_with "/system/apples") and not ([string tolower [HTTP::uri]] contains "fruits")}{
        HTTP::redirect "https://test.factory.com"
    if {[string tolower [HTTP::uri]] starts_with "/system/engine"}{
  • Hamish's avatar
    Hamish
    Yeah... You should be able to...
    You need to make sure the target of the link is set to _top (The target specifies which frame to open the doc in... _top is the top frame)...
    But to do that you'll probably need a double redirect (Since it's the requester that specifies the frame target, not the URL targeted). (i.e. The URL you redirect to needs to redirect (Could be back to itself) using the target attribute.
    H
